May 2, 2025 8:28 AM UTC
Unable to access PTC-certified Windchill Implementation Practitioner program.
I am trying to access the PTC-certified Windchill Implementation Practitioner program. Even though the credentials are correct, it states password incorrect. Can you help. Link to program - https://ptc.us6.list-manage.com/track/click?u=5199f8e357&id=a134d73db9&e=72ef8614d9
May 2, 2025 2:31 PM UTC
I'm assuming that you are a PTC partner and not able to access the link that you shared.
If this is the case, make sure your account is a partner account. If not, you can upgrade it, more information can be found here.
Once you upgrade it, retry the link.
If you're a PTC partner and your account is upgraded yet you still cannot login, please use the following link to log a ticket.
Click Field Academy > Login
https://support.ptc.com/apps/business_support/auth/ssl/assistant
