Aug 17, 2023 7:18 AM UTC
Will precision lms work in offline
hi,
  will the offline precision lms server work nowadays. If not is there any offline material for learning creo basics. creo7.0
Aug 17, 2023 11:29 AM UTC
You may try to install Creo Help files locally - "How to specify Help Center installation directory, installed on network drive, in Creo Parametric": https://www.ptc.com/en/support/article/CS59447
Aug 17, 2023 1:48 PM UTC
Precision LMS does not work offline. Vladimir's suggestion of installing the Help Center locally is a good one. Within that help center there are some tutorials. The link to those tutorials in the Help Center is here.
7-Bedrock
Aug 18, 2023 6:39 AM UTC
will help center work if pc is offline also without internet
Aug 18, 2023 3:19 PM UTC
The online help center will not work offline. However, you can download the Help Center from the same location you download Creo Parametric and any other PTC product. You can then install the Help Center locally on a PC, and then set a config.pro file so Creo knows where the Help Center loadpoint is. At that point, as long as your Creo licensing is local to the pc then everything can be offline.
