Dec 24, 2013 6:44 AM UTC
'Check in As' multiple topics
Hi All, I am pretty new to Arbortext and I am facing a problem. I have a couple of projects under a root folder and each project has multiple topics. I created a new project and I wanted to 'Check in As' the topics from the projects to the new project. However, it has really become a tedious task as I have to manually 'check in as' each topic one by one. Is there any way I can manually 'check in as' multiple topics at the same time?
What I am currently doing is that I first view the topic and then use the option SDL Live Content > Check in As.
Any help would be hugely appreciated.
Thanks in advance.
Avishekh
Apr 8, 2014 1:01 AM UTC
Hi Avishekh
That sounds like an SDL Live Content issue. Check with your rep or SDL technical support.
Liz
