Jan 7, 2016 11:25 PM UTC
Designing Injection Molded Parts for Manufacturability Using PTC Creo Parametric
- 0 replies
- 1454 views
- Translate All
PTC Creo Parametric has a robust set of tools to quickly design and analyze injection molded parts that can readily be tooled and molded. 3D Thickness, Plastic Flow and Draft Analysis tools built within PTC Creo Parametric will be demonstrated in a practical application along with design tools such as trajectory ribs, point patterns, variable pull direction draft and coordinate system UDF's that will help streamline part design times. Best practices to design for tooling and molding will also be shared during this engaging presentation.
Presented by: Doug Hippe, Extreme Tool & Engineering
See all PTC Live Global 2015 - PTC Creo and CAD Presentations
