Nov 8, 2011 7:49 PM UTC
How to create a keyboard shortcut for the "Find --> Find Tag/Attribute" menu item
I am trying to create a keyboard shortcut for the Find --> Find Tag/Attribute menu item. I know I can go to the command line and type:
map F2 command-name
Unfortunately, I don't know what the command name is for this and I don't see it anywhere in the Help.
Anyone have any ideas or suggestions?
P.S. I am using ArborText v5.3
Nov 8, 2011 8:18 PM UTC
In Arbortext Editor 6.0 the command is "map F2 FindTagAttribute". I do not have Arbortext 5.3 so let me know if this doesn't work for you.
Nov 8, 2011 8:21 PM UTC
Thank you Phil!
The command "map F2 FindTagAttribute" definitely works in ArborText 5.3
