Oct 24, 2014 12:16 PM UTC
Licensing
Do all licenses (single seat & network licenses) issued as part of the Academic Program for Australian Secondary schools work with a downloaded copy of Creo 3.0 from https://support.ptc.com/appserver/auth/it/esd/academic.jsp? If not are there any requirements to update licensing to use Creo 3.0?
    Oct 24, 2014 9:30 PM UTC
    Hi Shaun, simple answer is no. I am seeking clarification from PTC but at this stage, I could not recommend an upgrade to 3. It appears only the student edition is available using the common code on the web sit ein the pdf instructions regarding Creo3. I am unimpressed by that.
