Jun 14, 2012 2:33 PM UTC
Using FOS in ArborText PE Interactive Help
I am new using ArborText PE.
My problem is the following:
I have received a project with the structure:
- configure (.acl files)
- doctypes (A catalog with .atd, .cmd, .dtd, .fos)
- documents (My sgm file)
- entities (.CFG and .ENT files)
- ifos (All the portions of ArborText Style)
Firstly, I don't know how to import all this files into the ArborText PE.
The finallity is if I could use the template into doctypes/dm/5.4/dm_descript_aecma180/dm_descript_aecma180.fos (inside the file, there are all the fos styles)
I tried from the menu Format/Select Stylesheets and selecting the dm_descript_aecma180.fos but it doesn't run.
Can Anybody help me, how to configure all that files in ArborText PE?
18-Opal
Sep 27, 2012 2:40 PM UTC
Hi Ivan--
These files should all go into a custom directory, as described in the Arbortext Help Center (search for "custom directory"). Once you have this set up, then you can define an APTCUSTOM environment variable to point to the custom directory, and Arbortext will find your files and use them.
For some tips on different ways to configure this, take a look at my recent blog posts on Deploying Arbortext Customizations, at http://www.terraxml.com/community/blog/bid/211629/Custom-Arbortext-Editor-Deployments-Part-1 and http://www.terraxml.com/community/blog/bid/211630/Streamlining-Custom-Arbortext-Editor-Deployments-Part-2
--Clay
