Oct 24, 2012 8:39 AM UTC
Wants to change the association between WT part and EPM document
Sir,
let me explain the senario,
First we created EPM document using java program and created WT part using “windchill wt.load.LoadFromFile –d c:\PTC\dummy\part.xml - CONT_PATH /wt.inf.container.OrgContainer=AL/wt.pdmlink.PDMLinkProduct=H4” script(OOTB Script).
To make connection between WT part and EPM document we used
“windchill wt.load.LoadFromFile –d c:\PTC\dummy\partepmlinkloader.xml” Script.
Now the problem is WT part and EPM document associated under context relationship. Because of that not able to change the revision ,state for the WT part.
Normally WT part and EPM document should have owner association. So we request you to suggest how to change the association from context to owner. Matter is urgent we migrated almost 17000 parts.
For any clarification please call me at 9841723216 or mail to vsiva.alvvc@ashokleyland.com
V. Sivakumar.
    GregoryPERASSO
    Oct 24, 2012 9:07 AM UTC
    Hello
    Can you give an example of the content of the 2nd xml file ?
    cause I don't know if there's an OOTB script to create owner link
    content link is a "basic" and easy to create describe link
    But owner link is more complicated, as it is a "double* link (BuildRule + Buildhistory) and it synchronise and drive the WTpart BOM
    Anyway. you are able to import WTpart BOM with associated owner 3D CADDocs with the OOTB import/export tool.
    regards
    Gregory
    Oct 25, 2012 5:45 AM UTC
    This is the sample xml file.
    <?xml version="1.0" ?><!DOCTYPE NmLoader SYSTEM "standardX20.dtd">
    <NmLoader>
    <csvPartEPMDocDescribes handler="wt.epm.LoadEPMDoc.createPartEPMDocDescribes" >
    <csvfileName>FPartMigrationCheck.PRT</csvfileName>
    <csvdocVersion>#</csvdocVersion>
    <csvdocIteration>1</csvdocIteration>
    <csvpartNumber>FPartMigrationCheck</csvpartNumber>
    <csvpartVersion>#</csvpartVersion>
    <csvpartIteration>1</csvpartIteration>
    <csvpartView></csvpartView>
    <csvpartVariation1></csvpartVariation1>
    <csvpartVariation2></csvpartVariation2>
    <csvorganizationName></csvorganizationName>
    <csvorganizationID></csvorganizationID>
    </csvPartEPMDocDescribes>
    </NmLoader>
    GregoryPERASSO
    Oct 25, 2012 6:13 AM UTC
    Yes this one is only to create content link .... not owner link ...
    And nothing in the loader to create owner link...
