Dale_Rosema
Jan 11, 2019 12:43 PM UTC
2019-01-04 Friday Humor (Say again .....)
Be blessed in all you do this new year.
Continuation of definitions from this post: https://community.ptc.com/t5/PTCooler-OffTopic/2019-01-04-Friday-Humor-Call-it-what-you-will-Part-1/td-p/587490
"old faux pas" terms                                                            currently fashionable terms.
has an easy-to-understand, but hard-to-find solution:         obvious.
has two easy-to-understand, but hard-to-find solutions:      trivial.
truth:        tautology.
empty:        vacuous.
drill problems:        plug-and-chug work.
criteria:        rubric.
example:        substantive instantiation.
similar structure:        homomorphic.
very similar structure:                                                          isomorphic.
same area:        isometric.
arithmetic:        number theory.
count:        enumerate.
one:        unity.
generally/specifically:                                                          globally/locally.
constant:        invariant.
bonus result:        corollary.
distance:        metric measure.
several:        a plurality.
