Dale_Rosema
2022-11-23 Blessed Thanksgiving
For those in the US, have a blessed Thanksgiving. Make a list of all the things with which you have been blessed. Think of all the struggles that you have endured.
I thankful for my wife (of almost 35 years), my daughter and son, and two new knees this year!!!
Amazing things happen when engineers plan Thanksgiving.
Planning is key. Of course, as we all know, having a correct Bill of Materials (BoM), Process Plan, Measurement Plan and Part Drawings with GD&T are integral to a smooth Holiday Life Cycle (HLM).
Planning is Key - Determination of Build Objectives
Thanksgiving is a big event. When the family visits, it is important to have everything ready ahead of time. It doesn't do anyone any good to grab that bird last minute when it will take at least 6 hours to cook, unless the restaurant down the street is still open. For more information on that, see Appendix B.
Therefore, clear objectives were determined to be met with a concise action plan to deliver a high quality product to the customer. The goal of course is a zero defect process with controlled variation by building a robust design. No problem, right?
Okay, let's take a look at the objectives.
Build Objectives:
1. Perfectly cooked Turkey (not dry, or undercooked)
2. All food checked before delivery
3. Accounting for all tooling and users (everyone has a seat)
4. Proper levels of happiness (Happy Holiday! [marketing exclamation point])
Therefore, a process was set for creating the highest quality product possible:
1. Bill of Materials (not a shopping list)
2. Process Plan (not a table arrangement)
3. Part Drawings (not a recipe or seating chart)
4. Measurement Plan (not a temperature gage, or maybe a temperature gage but we're not sure)
1. Bill of Materials (BoM) - Make Sure You Have Everything
The BoM is very important to a high quality Thanksgiving dinner. Afterall, without the correct ingredients, there can't be a meal at all! (marketing's exclamation point for emphasis. Marketing loves exclamation points)
Called by the significant other, erroneously I might add, a shopping list, the BoM needs to include the key components for the final assembly. Strict adherence to proper part #'s is important for accurate tracking and measuring in the post-production environment. See Figure 1 for the THANKSGIVING BoM.
With the BoM complete, we can proceed to a Process Plan.
2. Process Plan - Know Your Cycle Times
When production begins, we need to have the workstations assigned, and placed accordingly. With proper cycle times listed, we can determine the production time from beginning to end. This will help determine the schedule so a delivery time can be established.
STATION 1: Cooking Station
All food is be prepared and cooked at STATION 1
STATION 2: Checking Station
Samples are to be checked by Quality Professionals (YUM! [marketing]) at STATION 2 to verify quality levels before being sent to the OEM (dining table) for final assembly.
STATION 3: OEM
Products are to be put into the final assembly for use by customer.
At a 10 hour cycle time for production, a start time should be set for 9:00 AM with an assumed delivery time of 7:00 PM. Due to variance in individual station time, and accounting for workstation user error, a 2 hour cushion should be built into the delivery schedule. Therefore, an effective start time of 7:00 AM is more realistic.
3. Part Drawings and Equipment Drawings - Tools Add Variation, Prepare For It Ahead of Time
A turkey takes time to produce (cook), and therefore, all variation that may cause a non-conformance issue needs to be accounted for. There is no room for error with the turkey, as a new one cannot be quickly produced, and using Functional Build rework causes additional build time and may produce additional dimensional and material defects (don't burn it...).
Strict adherence to proper datums and locators is important to provide uniform heat distribution during production, and proper sub-assembly dimensions and quality.
Tooling can also cause variation of overall production quality, and is important to be mindful of. With the table cloth and Thanksgiving decorations scattered on the table, we now have a profile tolerance of +/- 0.5 CM, or 5 MM, which is unacceptable. Additional safety precautions and checks need to be established to account for this error to reduce spillage and liability.
In addition, with a tolerance of 12 +/- 1 guest, it is hard to determine the optimum chair configuration. Several DoE (Design of Experiment) tests need to be conducted in order to determine the correct configuration. Additional consultants will need to be brought in (talk to the significant) to account for the additional labor [half]hours. The Tooling Supplier will need to be contacted and informed of unreasonable amounts of variation and fined accordingly.
Simulation is recommended based on historical data in order to better prepare both the tooling and the design itself. Using top of the line tools, such as a TASTE of HOME Cookbook and new computer simulated tools (CATIA), the product can be mapped out and toleranced (FT&A). Bringing this into 3DCS, an appropriate variation analysis shows that the primary contributor to variation will be BASTING. Therefore, additional measurements should be added to this process to track it thoroughly for variance during production to reduce scrap and drying. (Definitely buy a better timer and new digital thermometer)
4. Measurement Plan - How Do You Check Your Quality?
How do we know that the dinner is ready and of appropriate quality? Haphazard measurement processes, such as the pop out thermometer, are only roughly accurate. A more indepth measurement plan will make the process more reliable and corrective action more effective by giving the user a better understanding of minute by minute quality levels.
With the measurement plan in place, proper gages (thermometers) can be placed at the respective locations and monitored in real time through the stationed quality professional (I'll be staring at the bird through the oven window at the 8 thermometers in it). This will deliver a clear picture of the product's total quality levels, rather than just checking a single part using basic locators  and hand gages (the thermometer that comes in the turkey).
Conclusions
With a strong plan in place, and clear objectives, there is only a small percent chance for an out-of-spec product (estimated at 2.5% based on Reasons).
Utilizing modern processes and techniques, the chances for this to be a HAPPY HOLIDAY are dramatically increased.
We hope you, too, have a great holiday, and thank you for your support and business this season.
MarcoTosin
Well done.
As a task for next year, you could replace the thermometers with an IoT version and connect them to a platform that sends, in real time, the temperature to your phone.
That way you can be with your family during the cooking process instead of in front of the oven checking the status.
Marco
Dale_Rosema
My thermometer at home has 4 probes that do send the temp to my phone.
When I am doing steaks, Each has it own probe and doneness setting.  🙂
