Dale_Rosema
2024-02-09 Friday Humor (Ushhhy -Gushhhy)
Pull your sweetie a little close this week in light of St. Valentine's Day. Maybe even splurge on that extra large box of chocolates (if that's what is liked). Skip the AI generated cards or LED activated songs.
An Engineer’s Valentine
(by Matthew Dalton)
I was alone and all was dark
Beneath me and above
My life was full of volts and amps
But not the spark of love
But now that you are here with me
My heart is overjoyed
You’ve turned the square of my heart
Into a sinusoid
You load things from my memory
Onto my system bus
My life was once assembly code
It’s now like C++
I love the way you solder things
My circuits you can fix
The voltage ‘cross your diode is
much more than just point six
With your op-amps and resistors
You have built my integrator
I cannot survive without you
You’re my function generator
You’ve changed my world, increased my gain
And made my math discreet
So now I’ll end my poem here
Control, Alt, and Delete
