skunks
strength verification / little Creo-Tutorial
by amazon
This work is aimed at engineering staff and also students of all technical professions who are confronted with strength verifications. The focus is on the application of the Eurocode 3 standards to CAD solid models. In addition, an approach based on the FKM guideline is proposed.
In this course, most of the strength calculations are performed according to Eurocode 3, although some other standards and guidelines, e.g. the FKM guideline, are also considered.
The following examples are calculated through:
Wheel fork, analytical consideration
Wheel fork welded, Eurocode 3
Bracing welded, FKM
Casting made of aluminum, Haigh diagram
Stainless steel rope sleeve, Eurocode 3
Steel construction rectangular canopy
Stainless steel balcony railing
Pressure vessel made of free cutting steel
Special spring, forced elongation
