Mar 3, 2014 5:11 AM UTC
a big problem, creo2.0 can't set mapkey in 'F1'
in proe 5.0 and previous , I can set a maykey in 'F1' .
but creo 2.0 says "can't use F1" . when I press F1 , the help window come out . anyone know how can't I set "F1" as a maykey ???? It is very important to me. Thanks in advance.
Best regards.
Fu from China.
    Mar 3, 2014 8:06 AM UTC
    F1 key cannot be used as mapkey initiator, because it is reserved for launching a help. You cannot change this default behaviour of Creo Parametric 2.0.
    Martin Hanak
    Mar 3, 2014 8:10 AM UTC
    thank you . but pro 5, 4, 3 could do that. why proe change to bad. I am so annoyed. you know F1 key is really convienent for a maykey.
    Mar 3, 2014 4:00 PM UTC
    Isn't F1 key reserved for help more of a "certified for windows" requirement? Perhaps that's why.
    Apr 21, 2014 9:40 PM UTC
    I agree, that is bad. I have had $F1 as datums on/off since '98. Thanks PTC!
    Is there a way around this?
    Why don't they try to fix the "searching by caps" issue instead of breaking things that work?
    ::frustrated::
