a problem in updating parameters enclosed in symbols
I am using Creo Parametric Release 8.0 and Datecode8.0.3.0
I've created a symbol with parameters recalled inside and correctly saved and stored. But when I import the symbol in a 2D dwgs, parameters can't update but they remains with the construction &ptc_wm_version, &ptc_wm_revision etc.
If I use the same parameters outside the symbol (e.g. dwg frame or normal notes) they actually work and assume the value assigned to the parameters.
Here are the errors that I faced
N/A
Mahesh_Sharma
22-Sapphire I
Hi @CR_10169658,
When adding the parameter in symbol, define the value of parameter under symbol attributes as &PTC_WM_VERSION.
I hope this will help.
Thanks.
Mahesh_Sharma
22-Sapphire I
Hi @CR_10169658,
Thanks.
