adding mold component library to common folders
  • September 2, 2015
  • 2 replies
  • 1226 views
How is the config file updated to add the mold component folder so that it shows up in the common folder area of Creo 2?
Mahesh_Sharma
22-Sapphire I
September 4, 2015
Mark,
Are you looking for config option pro_library_dir? If you will install Mold library, set the config to library folder, this will add Mold library in common folders.
Mahesh_Sharma
22-Sapphire I
September 28, 2015
Mark,
Are you able to correct the Mold library issue?
