Nov 18, 2015 7:06 PM UTC
AMD Firepro Display Driver Crashing Creo Constantly!
My employer ordered me a new laptop recently and it arrived with an AMD card - apparently these gaming cards are 'approved' for Creo now, but of course it has constant issues. Several times a day I receive the error "display driver has stopped working". Then it recovers, but Creo goes blank and does not recover (and I loose my work). I've tried Dell tech support, updated my Bios, verified and reinstalled the latest AMD drivers... still the same issue. Any ideas or help on this would be greatly appreciated!
Thank you,
Brandon
Computer: Dell Precision M4800 Laptop
CPU: Intel Core i7-4810MQ @ 2.80GHz
Memory: 8 GB
OS: Windows 7 Professional (64-bit)
Display Adapter: AMD FirePro M5100 FireGLV    Driver Version: 14.502.1005.1002 (2/25/15)
StephenW
Nov 18, 2015 7:18 PM UTC
Usually I recommend the latest driver but sometimes it's best to go with the PTC approved driver.
http://support.ptc.com/WCMS/files/162683/en/dell_creo3.pdf
Precision M4800
Windows 7
32 and 64-bit
AMD FirePro 5100
12.104.2.4
07-Sep-2013
If you still have issues, contact PTC support since they have certified all the hardware.
bcampbell1-VisitorAuthor
Nov 18, 2015 7:21 PM UTC
Thank you Stephen, I'll give this a try!
Dec 9, 2015 5:39 PM UTC
Brandon, Did the "approved" driver resolve your issue?
Dec 10, 2015 9:19 PM UTC
FirePro is AMDs workstation class card.
Dec 11, 2015 8:40 AM UTC
Hi Brandon,
I have also had this issue and found the latest driver that works properly with FirePro cards and Creo is 13.352 on Windows 7
A little more info is here but refers mainly to windows 10.
MCAD Central
and
When will AMD release new FirePro drivers? | Community
Hope it helps.
Miles
Dec 11, 2015 10:43 AM UTC
I find the version 9 driver from 2013 offers the required features and stability for Creo 3. Earlier drivers don't meet Creo 3's requirements. If you have problems with the recommended driver, try that one.
