Sep 23, 2010 5:18 PM UTC
Anyone know the answer?
Thanks in advance for whatever help you might give. Where can I find a comprhensive list of all the config options in ProEngineer?
Sep 23, 2010 7:07 PM UTC
Search the PTC knowledge base for the following reference document numbers or select the links. There are different documents depending on the release you are interested in:
Sep 24, 2010 6:37 AM UTC
Thanks for that, you never know when I can use that info. I have saved it on my PC.
Regards
Chris
Sep 28, 2010 1:33 PM UTC
Here is a website you may also want to look at: http://www.proesite.com/.
If go to the utilities section and select the online utilities link there is one for the config.pro options. The utility also lists the hidden options if you want to try them out.
Sep 30, 2010 7:07 AM UTC
you can also try the pro-e help center, click help, help center, when the window appears, you will see books at the left hand, click this & you will see pro-e configuration, its a pdf document, its quite good actually, it details what is new, what has changed etc.
hope this helps
Regards
John
