Sep 7, 2016 7:58 PM UTC
Anyone knows how to switch Pro/E UI to Creo UI?
Currently, we use academic version Creo Element.
Config.pro ui_theme has only three options.
Widfire 5.0
Wildfire
Standard
Sep 7, 2016 8:17 PM UTC
Not possible!
The UI is dependent on too many things that have changed and is embedded into the code itself.
StephenW
Sep 7, 2016 8:30 PM UTC
Maybe there is some confusion here. Pro/E Wildfire 5 was re-branded as Creo/Elements Pro when PTC decided to change the name of Pro/Engineer to Creo Parametric. Later, Creo 1 was released followed by creo 2, Creo 3, and soon Creo 4.
If you are using Wildfire 5 (also known as Creo/Element Pro) released in 2009, there is no way to make it look like the lastest release of the software.
