Jan 20, 2015 11:28 PM UTC
Anyone running Creo3 date code M20 on MacBook Pro?
I have a MacBook Pro (Retina, 15-inch, Early 2013, 2.8 GHz Intel Core i7) It was runniing Creo 3 M10 datecode just fine under BootCamp. Creo kept reminding me on startup that the M20 datecode update had been released.
As I wanted to install the keyshot plugin, I thought I might as well update first. Disaster.
Lots of things that could have been what often gets called "graphics errors" - so when selecting tree filters on the model tree, click in a box to tick or untick and nothing happens, close the dialogue and reopen it and yes, they had been selected, but not dislpayed. Just one example but the whle GUI became hobbled, things disapeared from the top 'ribbon' menus, blank patched where items should be revealed.
But not just graphics. The scrollwheel zoom just totally stopped working, in fact all middle mouse button motion control was disabled.
It was so 'hobbled' I removed it (even the software removal was corrupted) and re-installed M10 datecode. It is now working again.
So, question, is anyone else out there running Creo3 M20 on this version of the MacBook Pro successfully?
Also is anyone running it on the latest MacBook Pro sucessfully?
Lastly, anyone encountering similar errors on an "approved" machine. Obviously PTC don't approve Macs and doubtless Mac are too arogant to submit their machines to PTC for approval - so doubt that will ever happen, but intrigued to know if approved machines suffer similar issues.
Oh and one last question why is creo_2.0 listed as a popular tag but not creo_3.0, is no one using it?
Stephen
2-Explorer
Jan 21, 2015 5:14 AM UTC
Creo 2 was released a long time ago and has a lot of users and Creo 3 was released recently and has far fewer users.
Did you save or copy the config.pro file on the install of M020? Were you using the graphics win32_gdi config option?
Jan 21, 2015 9:35 AM UTC
...would hve thought it might still be a "popular" tag, although not at all popular with me currently.
First I did an "upgrade" type install that used ts defaullt config file, the one it places in the install directory, then I was using the same config.pro file as previously with M10
Then I did a "fresh" and again I used its defaullt config file, and again then used the config.pro file as previously with M10, once again loads of graphics inconsistencies as described.
I didn't alter any graphics options, so not sure if I was using the one you mention, I certainly would not have picked it though as it has 32 in the title and the MacBooks have been 64 bit for some years.
The only think on the graphics was that Concurrent Enginering (my PTC support in UK) suggested my driver was old, about 9 months old, and should be updated. I updated that and it made no diffference to M20's corrupted behaviours and if anything made M10 run slower than previously.
On the original question, are you running on a MacBook Pro?
Thanks for the reply.
Stephen
2-Explorer
Jan 21, 2015 7:01 PM UTC
The configuration option "graphics win32_gdi" tells Creo to not use the graphics accelerator or drivers, bypassing incompatibilities. It has nothing to do with 32/64 bits.
Of the many apps that are nice on a Mac, the particular hardware is not what I would select for CAD work. The lack of Quadro support is the primary issue. It looks like your model has a video stream decoder in the Iris Pro section built into the i7 and a GeForce, which is a gaming level device.
Feb 1, 2015 7:39 PM UTC
I am also running Creo 3.0 on my MBP 13". Using BootCamp with Win7. I used it last night for a model working fine. When i went to shut down computer, Win7 automatic updates began, (4 updates in total). I let it go through since it starts automatic. Woke up today to continue modeling, and now mouse scroll is not working for ZOOM or MANIPULATING. Mouse Scroll unrecognizable. I tried in browsers and other programs and scroll is working fine. Went to Costco and purchased another mouse Logitech ANywhere MX. Still not working. I thought i was the only one. I did not read what updates was it making last night.
Hope there is a workthrough. Please advise. Thank you.
Best Regards,
David
Feb 1, 2015 7:57 PM UTC
Hi David,
You didn't say what datecode you were using on your MBP, if M20, then perhaps like me you could revert to M10 to retreive the functionality. I did try to bash on without the use of the mid mouse button, and like you tried a different mouse as I assumed it was that and not the software that had failed - (I've had plenty of mice that have failed over time, but never had ProE, even from pre-Wildfire to now fail to recognise the middle mouse button) but very difficult to use Creo like that.
You will see help here to do with graphics cards that can't handle OpenGL (as fas as I'm aware the MPS can, you don't say the specific spec, but mine does) and need to somehow do that in software on the CPU, but I think this is more fundamental and not related to the graphics card - that was the opinion of my PTC support experts anyhow.
Interesting you are running W7, so am I, and yest the latest "auto updated" version.
Let me guess, no other application lost MMB functionality, just Creo?
Good luck.
Stephen
Feb 1, 2015 8:07 PM UTC
Hello Stephen. Thank you for your reply. I am sorry since i am not too familiar with the program since i am a student and currently began using Creo 3.0.
I managed to download some software on the new mouse i bought (Logitech Anywhere MX) and managed to retrieve functionanilty on the scroll and scroll button with some configuration it allowed me.
Tested Creo 3.0 and working flawless. Luck i guess.
Thank you for your response and feedback. Really appreciated.
Note: I'm sure this wont be the best workaround for some out there since i just bought new mouse that permiited the config. It would be good to make it work with current mouse and not purchase other. There has to be some config to do in Creo 3.0 to make it work with current hardware.
Best Regards,
David
