Dec 22, 2014 3:07 PM UTC
Assembly constraints
I have been assembling a large amount of parts and subassemblies lately and thought it was time to ask this question:
Is there a config option I can set that I can have:
1. Coincident set automatically as the first constraint type?
A. I would select the references
2. Distance set automatically as the second constraint type?
3. Distance set automatically as the third constraint type?
If not I suppose I could write a mapkey that would achieve this for me....
Thank you for your time and assistance...
DRFaustAnswer
Dec 23, 2014 1:10 PM UTC
By setting the config options per a reply from Stephen Williams2
comp_angle_offset_eps = 91
comp_normal_offset_eps = -1
auto_constr_always_use_offset = never
Assembly works perfect as would expect it to.
Dec 22, 2014 9:12 PM UTC
I haven't seen any defaults that do this. However, there is a "repeat" functionality that can help.
create_temp_interfaces yes
This is when you assembly the same part over and over.
Is there anything un UDF for this?
DRFaust12-AmethystAuthorAnswer
Dec 23, 2014 4:45 PM UTC
Thanks Mike. What exactly do these do differently?
