Dec 23, 2014 2:08 PM UTC
Assembly mode, pick the parent, not the child
Hi All,
is there a config setting, so that when I do my assemblies, i can pick the assembly, and not the part / child of the inteded sub assembly?
I have an assembly, and in that assembly I have parts and other 'sub assemblies'. I'd like to click on a part (of the inserted sub assembly), and have it select the whole sub assembly, as it was brought into the main / larger / master assembly. I want to pick / click / select the sub assembly part, and not have to 'click - select parent, click select parent, click-slelct parent' all the time. A few times, i go too far and the thrid or fouth 'slect parent' gets me to the top of the assemlby chain!
Yes, i can pick the sub assembly from the assembly tree, but with 100+ parts / sub assemblies, I never remeber the part No., and contstatnly scrolling up & down in the list is tiresome. That part (assembly), there, is what I want..
I have a lot of panels with PEMs & such. I have a few sub assemblies; weldments, as well. And I just want to grab that assembly / part with one click. It is how it was bought into the main assembly.. In my mind, that's how I should select it, not the individual sub-sub component
StephenW
Dec 23, 2014 2:38 PM UTC
I don't believe there is a setting. Best answer other than the already mentioned right click select parent is right click - pick from list to get the query select box to come up. It gives you a complete list of everything "behind" the mouse pointer.
Not really what you are after but maybe another tool to help you move faster.
