Sep 18, 2010 6:50 AM UTC
Automaticaly create a drawing each time we create a part or an assembly
Hi alls,
I can't remember where we can set this option on or off.
What is the config.pro command that can enable or disable proe to automaticaly create drawings ?
GB
Sep 20, 2010 6:04 AM UTC
If your template_drawing has the same name as you template_solidpart and
template_designasm e.g. start.drw, start.prt/start.asm then a drawing will
be created.
To avoid this we have our templatedrawing named start_.drw.
I am not aware of any config option handling this behavior.
Bjarne
g bon <->
18-09-2010 08:51
Please respond to
g bon <->
To
cc
Subject
[proecad] - Automaticaly create a drawing each time we create a part or an
assembly
Hi alls,
GB
Site Links: View post online View mailing list online Send new post
via email Unsubscribe from this mailing list Manage your subscription
Use of this email content is governed by the terms of service at:
Sep 20, 2010 12:07 PM UTC
I am not sure if this is what you are looking for, but if you use a "start
part" or "start assembly" and there is a drawing associated with that
"start part" or :start assembly", the config.pro setting
rename_drawings_with_object BOTH
will save the newly created part or assembly drawing with the new name.
It has been so long since we first set this up, that I don't remember if
there are any other settings or not, sorry.
Good luck,
Bob Frindt
Sr. Designer
Parker Hannifin Corporation
Parker Aerospace
Gas Turbine Fuel Systems Division
8940 Tyler Boulevard
Mentor, OH 44060 USA
direct (440) 266-2359
cell: (216) 990-8711
fax: (440) 266-2311
www.parker.com
g bon <->
09/18/2010 02:50 AM
Please respond to
g bon <->
To
cc
Subject
assembly
Hi alls,
GB
privileged. It only should be used or disseminated for the purpose
of conducting business with Parker. If you are not an intended
recipient, please notify the sender by replying to this message and
then delete the information from your system. Thank you for your
cooperation."
Sep 20, 2010 12:39 PM UTC
The config.pro option 'rename_drawings_with_object' controls this
behavior. I believe you need to set it to 'none' (and I think this is
the default).
Doug Schaefer
