6-Contributor
best practice to reuse Spools in Windchill
I am using Creo Parametric Release 8.0 and Datecode 8.0.8.0
What is the best practice to reuse Spools in Windchill?
cgautierAnswer
18-Opal
Hello VS_10459213,
In cabling there is pro_spool_dir that points to location from where read cabling spools...
this means it can be any path on local machine.
customer may need how set this path to Windchill.
KR,
Charles.
18-Opal
Hello VS_10459213,
I'm Charles from PTC Technical Support in Europe: can you provide extra details what is meant by spools ?
Any detailed use-case?
KR,
Charles.
6-Contributor
Hi Charles,
Use case is : Two users would like to commonize the spools we use for the cabling module.  Is that a directory we set up in the config.pro or is there a way to set the location of spools in Windchill?
cgautier18-OpalAnswer
18-Opal
Hello VS_10459213,
KR,
Charles.
18-Opal
Can you review kb article CS48213 ?
