Best practices for updating Creo date codes
  • April 21, 2016
  • 9 replies
  • 6210 views
Hi everyone -
I was wondering what procedures other people have in place for updating Creo date codes as they are released. Do you always stay one behind the most current? Or maybe more that one behind? Or maybe you always stay current with the latest release.
We have recently updated from WF4 to Creo 3 and would like to start using better habits when updating our software. Currently we are on date code m050 and I know right now the current is M090 so we're starting to fall behind.
Any information is greatly appreciated.
Brandon
Best answer by BenLoosli
A lot depends on what issues we have with the current running build. We also have to account for the version of Windchill that we use.
I am on Windchill 10.0 m040 with Creo 2 M100 and have no immediate plans to update to a newer build as we don't see any issues where we are.
If I need to update prior to Windchill 11.0, I will do that when I get into the final stages of the Windchill planning and testing. Once I get to Windchill 11.0, we will probably do an upgrade to Creo 3/4 depending on the timing.
I usually do not run Wildfire/Creo builds lower than m060 in production, so I have to look closely where those releases fall in the timeline.
BenLoosli23-Emerald IIIAnswer
We stay pretty up-to-date. There's always something pushing us forward. We update Windchill to support the latest CAD versions, and update Creo roughly every fourth maintenance release. We went from M050 to M090 last week to support Windows 10.
3-Newcomer
July 27, 2016
How do you perform the upgrades?
e.g. M090 to M100
I have seen that there are Subfolders Mxxx in the Common files Folder, but the parametric and simulate folders have no shipcode in the path.
Do files change only in the common files folder between shipcodes?
My Idea would be to deploy new creo shipcode to all clients over the week.
After everybody has received the new Version I can change the shipcode for the shortcuts globally.
A quick comparison shows that the files inside the parametric folder do indeed change between builds.
Almost all of our users run Creo from a read-only network location, so in our case I simply install the newer build on the server, add our configurations, and then change the path in our startup script to point to the new build.  If we have any issues I can easily change the script back to any earlier build and the users won't even know it happened.
balmas1-VisitorAuthor
Tom,
How many users do you support in your organization with this method? One of the challenges we face is finding an efficient way of upgrading builds on each local users machine.
How were you able to configure Creo to run on local machines from the server?
