Jan 24, 2014 4:16 AM UTC
BoM Balloons get scattered in Creo 2.0
Dear all,
Recently I have switched over to Creo 2.0 from Proe WF 4.0.
I am placing BoM balloons in the drawing for very large assembly with simp reps.
I keep all balloons lines vertical and save the drawing.
When I open drawing again at that time all balloons get scattered. I donot know whether it is becuase of any change in assembly or it has to do something with config file.
Thanks.
Vimlesh
Jan 24, 2014 4:37 AM UTC
You might see if it is due to an explode state being active in the assembly. I have seen some weird things happened with the explode state active even if the view has nothing to do with it.
I would also recommend capturing your situation and forwarding it as a support case. Just save a file set and a process where this is easily repeatable. You can then submit the files and process to show what is happening.
