2-Explorer
Apr 29, 2013 10:22 AM UTC
Browser Homepage
We have just changed to WF4 from WF2.
In WF2, we had the default browser homepage set to start the Pro/E help center. I changed the address in config.pro to point to the WF4 default.htm page (or so I thought) and it stubbornly remains pointing to the (now non-existent) WF2 path.
I have tried quite a lot of different combinations of file://xxxx<file: \\xxxx="> and http://xxx
May 17, 2013 5:53 PM UTC
We have just migrated to Intrailnk9.1.....yes, finally. I know there's no "briefcase" feature in Ilink9.1, but is there a workaround that can be done?
Thanks!
Calvin
________________________________
May 20, 2013 8:20 PM UTC
Hi Calvin,
You can create a 'Saved Search' with multiple Name-fields. This way, your users can search for multiple CADdocuments in one go, select them all and add them to the workspace.
Regards, Hugo.
