Aug 13, 2013 8:26 AM UTC
Can Attribute "PTC_WM_LIFECYCLE_STATE" be used for publish rules?
Our requirement is to generate the EPMdocuments once the drawing is published through post-publication using publish rule.
Particularly, it should post-publish only the drawings which are having PTC_WM_LIFECYCLE_STATE=Released.
However, when created a PublishRule.xml with below lines it does not work. Drawing withPTC_WM_LIFECYCLE_STATE=Released are not getting post-published.
It does not consider value for parameter:PTC_WM_LIFECYCLE_STATE and post-publication does not happen.
<rules xmlns="&lt;/span">http://www.ptc.com"
 xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="
http://www.ptc.com
PublishRulesSchema.xsd">
 <authoring-application name="PROE">
<epm-iba iba="PTC_WM_LIFECYCLE_STATE" value="Released">
<publish on="checkin" param-set="Post" publish&quot;="/>
<publish on="create-representation" param-set="Post" publish&quot;="/>
<publish on="schedule" param-set="Post" publish&quot;="/>
</epm-iba>
<param-set name="Post" publish&quot;=">
<post-publish name="delegate">com.ptc.wvs.server.publish.EPMPostPublishDelegate&l
t;/post-publish>
<post-publish name="type">wt.doc.Document</post-publish>
<post-publish name="name">{EPM_NAME}_temp</post-publish>
<post-publish name="number">{EPM_NUMBER}_temp</post-publish>
<post-publish name="published-content-link">create</post-publish>
<post-publish name="container-oid">wt.pdmlink.PDMLinkProduct:79086986</post/> -publish>
</param-set>
</authoring-application>
</rules>
alonkar-21-VisitorAuthor
Aug 13, 2013 4:35 PM UTC
Hi Lance,
The syntax is not the issue. Sorry it was a typo while pasting here. It is written correctly in xml file on server.
However, problem is with "<epm-iba iba="PTC_WM_LIFECYCLE_STATE" value="Released">"
Our requirement is that post publish should happen only with the drawings which are having a life cycle state as "Released". And it will create EPMDocument after post-publish.
So we are trying to use the parameter "PTC_WM_LIFECYCLE_STATE" to verify this condition of "Released" state.
However, with this parameter used as a check for post-publish it is not working.
Best Regards,
~Amit Lonkar
20-Turquoise
Aug 13, 2013 8:38 PM UTC
On 08/13/13 11:35, amit lonkar wrote:
> Hi Lance,
The value you should compare against is uppercase "RELEASED".
Lifecycle states are all upper case and no spaces for the values used in the software.
ie: "In Work" display value is actually "INWORK" internal value.
> Best Regards,
> ~Amit Lonkar
> *From:*Lance J Lie [
> Amit,
> Is syntax the issue? I highlighted it in red. The string </post-publish> isn't closed.
> </epm-iba>
> <post-publish name="delegate">com.ptc.wvs.server.publish.EPMPostPublishDelegate*&l **
> t;*/post-publish>
> <post-publish name="container-oid">wt.pdmlink.PDMLinkProduct:79086986</post<br/>> -publish>
> </param-set>
> */Lance J Lie/*
> Information Technology
> SAS IT Info. Solutions App. Eng.
> Space and Airborne Systems*
> Raytheon Company*
> +1 310.616.1551 (office)
> +1 310.426.4968 (cell)
> +1 310.647.0315 (fax)_
">mailto:->
> 2000 E. El Segundo Blvd.
> El Segundo, CA 90245 USA_
> _www.raytheon.com
> To: - <
">mailto:->
> Date: 08/13/2013 01:31 AM
> Subject: [viz] - Can Attribute "PTC_WM_LIFECYCLE_STATE" for publish rules?
> Hi,
> However, when created a PublishRule.xml with below lines it does not work. Drawing with PTC_WM_LIFECYCLE_STATE=Released are not getting post-published.
> It does not consider value for parameterSmiley TongueTC_WM_LIFECYCLE_STATE and post-publication does not happen.
> <rules xmlns="&lt;a" style="COLOR:" blue;=" text-decoration:=" underline&quot;=" target="_BLANK" href="http://www.ptc.com"">http://www.ptc.com"
<">http://www.w3.org/2001/XMLSchema-instance%22>
> </epm-iba>
> t;/post-publish>
> </param-set>
> </rules>
> -----End Original Message-----
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
Aug 14, 2013 5:45 AM UTC
Hi Randy,
Changing the Value to Uppercase did not work.
It does not work even if I don't put the value for parameter like: <epm-iba iba="PTC_WM_LIFECYCLE_STATE">
I think it does not recognize the parameter 'PTC_WM_LIFECYCLE_STATE' itself.
Any idea how to make it work?
Best Regards,
~Amit Lonkar
TomU
Aug 14, 2013 1:02 PM UTC
I could be completely off base here....
I don't think the publisher is anything more than a toolkit app. Also, aren't the files transferred from Windchill to the publisher via ftp or network folders? I am wondering if Pro/e is actually connected to Windchill during the publishing. The PTC_WM_LIFECYCLE_STATE parameter is only visible when you open a part while connected to Windchill. If you directly download a part out of Windchill (download as in downloading a file from a website) and then open it in Pro/e, you will notice that there are multiple parameters no longer listed that ARE listed when the same part is opened in a linked session. Here are the ones I'm seeing on our system:
PTC_ORGANIZATION_ID
PTC_WM_REVISION
PTC_WM_ITERATION
PTC_WM_VERSION
PTC_WM_LIFECYCLE
PTC_WM_LOCATION
PTC_WM_CREATED_BY
PTC_WM_CREATED_ON
PTC_WM_MODIFIED_BY
PTC_WM_MODIFIED_ON
PTC_WM_TEAM
DOC_CNTL_STATUS
NONE of these are visible in Pro/e unless the file is opened from Windchill directly.
Tom U.
