Oct 23, 2015 8:34 PM UTC
Can I use the WF 2.0 license server install on Win7
I'm trying to move an old license to a new server. Got a new license file and ran the WF2.0 PTC install from the old disk for the license server. It seemed to go OK but it won't allow the server to start. The license pieces don't generate any errors - but when it finishes it says couldn't start license server and it points to a .log file that is supposed to be down in the flex directory but it isn't there.
Does this old installer not support Win7? Where would I get a newer one?
-Dan
Oct 23, 2015 10:58 PM UTC
Try turning off the firewall on the system and see if that lets you start the license server.
There are some additional trouble shooting tips at the end of this presentation.
http://portal.ptcuser.org/p/do/sd/sid=2464&type=0
Nov 3, 2015 7:33 PM UTC
I turned off the Firewall - that didn't help
I changed the folder number for the NIC via regedit - it was at 8... changed it to 1 & rebooted still doesn't start.
The status says it's been changed (see below) - I don't think I did that. I downloaded it as they mailed it to the machine. I might have opened it with WordPad or something.
Thanks for the help so far,
-Dan
port or hostname in the license file has been changed.
Server name:   xxxxxxx
License path:  yyyy@xxxxxxx
FLEXlm error:  -15,10.  System Error: 10061 "WinSock: Connection refused"
For further information, refer to the FLEXlm End User Manual,
available at "www.macrovision.com".
Status
Flexible License Manager status on Tue 11/3/2015 14:18
[Detecting lmgrd processes...]
License server status: yyyy@xxxxxxx
    License file(s) on xxxxxxx: C:\PTC_Server\flexlm\licensing\license.dat:
lmgrd is not running: Cannot connect to license server
The server (lmgrd) has not been started yet, or
the wrong port@host or license file is being used, or the
