Oct 26, 2015 6:58 PM UTC
Can not modify hose created in WF4
I'm currently using Creo 2.0 and I need to modify a hydraulic hose that was created in WF4 using Pro/Piping. I'm about to pull my hair out because I can not modify this model at all. Here is what I have done/checked:
1. I made sure that the model is not set to read only and I have confirmed that I can make changes to the model.
2. The pipeline will display in "Thick Pipes" mode, but I can not figure out how to make it show the pipeline segments as centerlines (the green lines).
3. I have tried Modify Pipeline and it will not allow me to select anything in the model or anything on the model tree.
4. I have tried using the Find tool and did a filter by pipe features and it shows nothing.
5. I have checked my company's config.pro settings and there are no piping related options set.
Does anyone know what I am doing wrong? Its like the pipe solid is there but none of the pipeline segments will show up in the model.
lernst-2Answer
Oct 26, 2015 7:06 PM UTC
See if the assembly layer tree has the piping centerlines hidden.  You will have to un-hide it to see them.
StephenW
Oct 26, 2015 7:03 PM UTC
Is it that the pipe features are in an upper level assy?
Oct 26, 2015 7:05 PM UTC
The pipe features are in the hose assembly model along with two end fittings.
lernst-21-VisitorAnswer
Oct 26, 2015 7:09 PM UTC
Yup...on the wrong layer. It is definitely Monday.
