Oct 15, 2015 12:02 PM UTC
Can't reconfigure
Hi
I'm running Creo 3.0 through Prallels on my mac. Suddenly it stopped working, and when i try to open af file it says that I have to reconfigure:
Problem is I don't know how to do this. When I'm running the setup-file, it will not let me choose reconfigure under "install new software":
I'm using the free academic software.
Any suggestions how to solve this problem, so I can start using Creo again?
Best regards
Oct 15, 2015 1:39 PM UTC
Reconfigure.exe is a separate executable.  It is located in C:\Program Files\PTC\Creo 3.0\<datecode>\Parametric\bin (for Creo 3.0)
fhansen1-VisitorAuthor
Oct 15, 2015 3:16 PM UTC
Thanks a lot for the answer! I still can't find the Reconfigure.exe file in that location? Can it go by another name?
Anyway, do you know if I can uninstall Creo and install it again, without having problem with the license?
Oct 15, 2015 3:11 PM UTC
it looks like parametric.psf file was removed from C:\Program Files\PTC\Creo 3.0\<datecode>\Parametric\bin directory. It's hard to tell what happened in the virtual machine.
Note: If you do not know, where license file is saved, then you cannot resolve the problem.
MH
Oct 15, 2015 3:20 PM UTC
Ok, I'm using the academic edition, so do you know if, it's possible to get a new study-license somewhere?
Oct 15, 2015 4:15 PM UTC
You can contact PTC to request one.
Mahesh_Sharma
22-Sapphire I
Oct 20, 2015 11:06 PM UTC
Frederik,
Did you get answer for your question from any of the replies on this post?
For support on academic edition you can log a case at Academic Case Logger
