Can't start PTC Creo 3.0
Hello PTC Community, I'm in need of some help.
In our company we were using PTC Creo 2.0 but we accually had a license file for 3.0..
I downloaded PTC Creo 3.0 (MED-100WIN-CD-400_M070_Win64.zip) and installed it. Everything works great untill I tried running Creo. I get the same error when running Simulate.
I get following error:
I tried uninstalled and reinstalling it multiple times. Nothing I've done so far seems to help.
I really appreciate any help anybody can provide.
tlemaireAnswer
These two sentences basicly solved it:
- It seems to me that when you launch CR3, it finds wrong baselibmt.dll file (maybe file that belongs to CR2).
- On my PC C:\Windows\System32 does not contain baselibmt.dll file.
I sorted my System32 folder on date and time. I noticed i had a bunch of other DLL files (128 to exact) created on that date. I moved them all out.. Tried openening Creo 3.0 and it works..
SUCCES!
Thanks ALOT for the help.
Are you running a 64-bit OS?
Properties on your Computer icon will give this:
tlemaire1-VisitorAuthor
Yes
did you unzip MED-100WIN-CD-400_M070_Win64.zip and then launch setup.exe ? I use free 7-zip 9.20 software to unzip downloaded files.
MH
Yes, I unzipped the file (also with 7-Zip 9.20) before running the setup.exe (as administrator).
I stored the unzipped files in "C:\Temp".
I searched baselibmt.dll file on my local disk. I found this file in CR2+CR3 installation and unzipped DVD media.
  • search you local disk for baselibmt.dll file
  • check PATH variable
MH
I found it in CR2, CR3, System32.
Path file:
C:\Program Files\PTC\Creo 3.0\Parametric\bin;
C:\PROGRA~1\PTC\MKSTOO~1\bin64;
C:\PROGRA~1\PTC\MKSTOO~1\bin;
C:\PROGRA~1\PTC\MKSTOO~1\bin\X11;
C:\PROGRA~1\PTC\MKSTOO~1\mksnt;
C:\Program Files\Common Files\Microsoft Shared\Windows Live;
C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;
C:\ProgramData\Oracle\Java\javapath;
%SystemRoot%\system32;
%SystemRoot%;
%SystemRoot%\System32\Wbem;
%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;
C:\Program Files (x86)\Windows Live\Shared;
C:\Program Files (x86)\Skype\Phone\
on my PC C:\Windows\System32 does not contain baselibmt.dll file. Go to C:\Windows\System32 directory, rename baselibmt.dll file and test CR3.
MH
