Apr 14, 2014 8:52 PM UTC
Can you open a SolidEdge file directly in Creo? Creo View?
I have been told that you can open a SolidEdge file directly in Creo View Professional. I only have Creo View Express and do not see this capability advertised with any "professional" version. Can anyone tell me if any of PTC's Creo 2 applications can open a SolidEdge file directly? Any other way? Saving the SolidEdge file to a neutral format through SolidEdge is not an option, we do not have SolidEdge and only have access to the SolidEdge file.
Thanks in advance for the help!
Apr 15, 2014 5:43 AM UTC
Matt,
if you need to view SolidEdge files, only, then use SolidEdge viewer (I guess it is free, I found it using Google).
If you need to import SolidEdge files, then you have a bad luck (I am not 100% sure). Maybe Creo Parametric 3.0 will be able to open native SolidEdge model files (eg. .asm, .par).
Martin Hanak
Apr 15, 2014 6:55 AM UTC
Please check this link "PTC Creo Elements/Direct Interface for Solid Edge": http://www.ptc.com/product/creo-elements-direct/interface-for-solid-edge
Apr 15, 2014 7:04 AM UTC
Vladimir,
do you have some practical experience with SolidEdge import ?
From my point of view, Solid Edge Parasolid format = file with .x_t extension.
Martin Hanak
