Oct 17, 2014 7:24 PM UTC
Cannot Visualize and manipulate the HDR image environment.
Creo 3.0 m010. HDR (high dynamic range) environment for the model, In Shading with Reflections mode, with or without the Photolux license activated. The HDR image does not show up. Cannot Visualize and manipulate the HDR image.
dpasholkAnswer
Nov 20, 2014 8:41 PM UTC
Replaced old computer HP xw 8400, quadro FX 5500, with newer HP Z820 quadro K5000.
It works!
2-Explorer
Oct 20, 2014 12:58 PM UTC
Hi Dan,
you should probably open a case with Technical Support - especially in case you have seen it work before in F000.
Gunter
dpasholk1-VisitorAuthor
Oct 27, 2014 7:30 PM UTC
Case Details: 12215495
HI
Cannot Visualize and manipulate the HDR image in Creo 3.0 m010.
http://learningexchange.ptc.com/tutorial/3443/manipulating-hdr-images
I cannot get this to work.
Oct 30, 2014 12:43 PM UTC
Possible SPR
2-Explorer
Nov 3, 2014 2:37 PM UTC
Thanks for getting back to us!
Nov 10, 2014 6:45 PM UTC
issue is still under investigation Nov 10, 2014
dpasholk1-VisitorAuthorAnswer
It works!
