11-Garnet
CCX creates the necessary cross section while running CCX viewing the analysis results is terminated
I am using Creo Parametric Release 6.0 and Datecode6.0.6.0
1. CCX, which creates the necessary cross section while running CCX and viewing the analysis results, is terminated. Is it possible to do cross-section work while looking at the result in a state where it cannot be finished?
2. How to adjust the line drawing and thickness displayed when viewing CCX progress?
Translated this post from Korean to English at 1:37pm IST(done by vnamboodheri)
Subject was: CCX를 실행하고 분석 결과를 보면서 필요한 단면생성하는 CCX가 종료됨
Body was - 1. CCX를 실행하고 분석 결과를 보면서 필요한 단면생성하는 CCX가 종료됨. 종료 안되는 상태로 결과를 보면서 단면작업 가능한가요?
2. CCX 경과를 볼때 표시되는 선 생상이랑 굵기를 조정할려면 ?
