Nov 28, 2011 3:02 PM UTC
CGM file creation-Disable log creation
While creation of a cgm file using File->Save a copy... as *.cgm file, a log file is created along with the cgm file, with extension as follows, ......cgm__out.log.1.
Can we disble this log creation while the cgm creation by any settings?
e.g.
Solid_cgm__out.log.1
Solid.cgm
Nov 28, 2011 7:04 PM UTC
Hi RGE...
I don't believe you can suppress this log file. Don't take this the wrong way but... why do you want to avoid the log file? If the files are merely nuisances, maybe they could be removed by a simple script or a mapkey?
RGE1-VisitorAuthor
Nov 29, 2011 9:46 AM UTC
The log files created are of bigger size as it is writing lot of information in the log which in turn seems to be affecting the performance. So if I can disable the log, it may help improving the performance.
For a cgm file of size, 4211KB it is creating a log of 14658KB
Nov 29, 2011 6:58 PM UTC
Ah, I see. I don't believe there's a way to disable creation of this log via the interface. That is, there's not an option you can set to skip the log file.
I hate to give definitive "no" answers to questions because in Creo and Pro/E there are usually ways to work around most problems. In this case though, I think you're stuck.
Wish I had better news.
-Brian
