Oct 24, 2013 2:54 PM UTC
Changing default arrowhead on leader notes
Hello all.
Our company has recently upgraded to Creo 2.0 and I am hoping that somebody can assist with this question. I am looking for a way to change the default arrowhead for leader notes to always be an arrowhead. Currently, the default is "automatic" which means if you pick the surface of a part, it defaults to a filled dot. If you pick an edge or draft entity, it defaults to an arrowhead. I can change it to an arrowhead before I complete the note, but would prefer to have it always be an arrowhead. The help center lists, what I assume to be a config option, "default_leader_arrow_style", but a find in the config options area does not show any kind of reference to this option.
If you have any ideas or suggestions, please know that they are appreciated.
Thank you all for your time and assistance. Have a good one.
Oct 24, 2013 3:09 PM UTC
This is actually in the .dtl file not the config.pro.
Oct 24, 2013 3:12 PM UTC
Or you can access the dtl from within creo at File> Prepare > Drawing/Model Properies > Detail Options. There are separate ones for drawings and models.
Oct 24, 2013 3:23 PM UTC
Thank you for the assistance. I do appreciate it.
Have a good day.
