Jan 14, 2011 8:40 PM UTC
Changing the Name Displayed when showing the favorites
I work on a few projects at a time, with each of the project data
located in different folders. When we are making a 'brainstorm' idea
change to the parts, they go into a sub-folder located under the main
project folder, which is called 'experimental'. For example, there is a
folder called proe/housing/experimental and a folder called
proe/mount/experimental. I add these to my favorites so that I don't
have to click deep up and down the file tree to open files.
The issue is that these show in favorites as 'experimental' and
'experimental[1]', and I have no way of knowing which main project these
folders belong to (i.e. housing or mount). I would like to rename the
description so that I know which one is which, and not rely on my memory
to know that the [1] file is for the mount project.
Is there a way to rename what is displayed in the favorites folder?
WF5.0 M040
Bob Condra
Jan 14, 2011 9:05 PM UTC
Go to the favorites tab above the model tree, right click on one and
select rename.
Doug Schaefer
BobCondra1-VisitorAuthor
Jan 14, 2011 9:15 PM UTC
Thanks Doug, that is it. I was trying to rename it while opening
files, and it would not work.
Bob Condra
