Checkin error
"A referential integrity violation occurred for this operation" i got this error message while i performing check in process.and check in failed
please any sggest the solution for this..
Hello Sharath,
I think you don't need to find the answer after 1 year.
I experienced same error today.
When the connection corrupts for 1-2 seconds, the integrity violation error occurs.
I would like to find the answer for the error in this forum before I noticed the source of the problem. It take almost 2 hours to solve such an easy situation!
Good day,
Andaç
I get this same error without the connection problems. Error shows up after just a couple seconds.
has anyone found a solution to this yet?
Go to your upper level assemblies and removed missing references using the reference viewer and break dependencies option.
