clipping diameter dimensions
I'm back on to wildfire, I have a segmented part and am trying to show the diameter as a clipped dim but I can seem to get this to happen?
Is there a config setting to allow this? its been a while so can't remember
18-Opal
April 26, 2017
Hi Colin,
Which release of Wildfire are you using?
Amit
cdown1-VisitorAuthor
Sorry forgot to mention WF4 M220
18-Opal
April 27, 2017
Hi Colin,
To create a clipped dimension do the following:
  1. Select a reference
  2. Hold down the CTRL button and select a 2nd reference
  3. Continuing to hold down the CTRL button, select the 1st reference again
  4. Use the MMB to place the dimension
Let me know if that doesn't work.
Amit
