Jan 27, 2014 3:07 PM UTC
CMD does not close automatically after calling the parametric.bat file of Creo 2.0
Hello All,
I have created a batch file which sets everything for an user like configuration files, start in directory and finally calls the parametric.bat file. Everything works except the cmd window does not close automatially.
I can change the parametric.bat file to parametric.exe which works as expected. However, i would like to know why it does not work with Creo 2.0 whereas it was working with Pro/ENGINEER Wildfire 5.0.
call "D:\Creo2\Creo2\Creo2\Parametric\bin\parametric.bat"
exit
Thank you!
Jan 27, 2014 3:13 PM UTC
Hello there,
we have creo 2.0 m030 and it works fine for us.
1. we setup the shortcut started up and execute the parametric.bat This is a short cut on desktop or any program group. It is also where you set the working directory for creo parametric as well.
2. in the parametric.bat, we have all kind of environments for permissions and so on, the last line should be like so, exactly like the out of the box that parametric.bat has:
"C:\Program Files\PTC\Creo 2.0\Parametric\bin\parametric.exe" "C:\Program Files\PTC\Creo 2.0\Parametric\bin\parametric.psf" %*
*notes: you call parametric.bat from another DOS shell. that is why it is still open and not exit.
NiharPal1-VisitorAuthor
Jan 27, 2014 3:17 PM UTC
Thank you.
We have Creo 2.0 M060. I can get it to work if i call the exe file and psf file.
The method of calling batch file (proe1.bat) was working in Wildfire 5.0. I expect it should work in Creo 2.0.
Jan 27, 2014 3:27 PM UTC
disregard how you do in wildfire, it works for me as is. It should work for you if you just execute directly from parametric.bat or create a shortcut for it.
you can just put all your environments setup in that file before execute the parametric.exe
Jan 27, 2014 3:18 PM UTC
@echo off
start "Creo 2.0 Windchill" "E:\PTC\Creo 2.0\Parametric\bin\parametric.exe" "E:\PTC\Creo 2.0\Parametric\bin\parametric_wnc.psf" %*
Jan 28, 2014 11:02 AM UTC
Thanks Sergey.
I have it that way and it's working for me withouts issues. I was interested to know if there is any change in environment of Creo which is not allowing the CMD to close automatically.
Jan 27, 2014 3:54 PM UTC
Add empty quotes before the path ""
start "" "D:\Creo2\Creo2\Creo2\Parametric\bin\parametric.bat"
Jan 27, 2014 5:39 PM UTC
Hey ,
Does anyone else have trouble getting Creo to exit when hitting the close window "X"???
Buddy
