Apr 22, 2010 1:36 PM UTC
CoCreate on WIndows 7 virtual machine?
I have a 27" Apple imac. I run windows 7 (Professional) under vmware. In general, I've had excellent luck running windows applications in this environment. Cocreate fails to start up. I get the "no valid license" error. The software has never asked me for a username or password, I don't think it gets that far. I do get the PTC splash screen as it's trying to start up. Windows 7 Pro does have an XP compatibility mode; perhaps that's the answer. Has anybody got a configuration like this to work? Is this battle worth fighting, or should I just go looking for a different cad package?
Apr 27, 2010 11:25 AM UTC
Hello, as of today Modeling PE is not supported on Windows 7 and we have seen multiple reports now reporting that Modeling PE throws an error like yours on Windows 7. the best approach is to get a Windows Vista or XP to get this to run. Cheers Horst Note: That running on VM ware is also not supported and that you might have severe issues with your graphic running in VM Ware.
Jul 2, 2010 6:24 AM UTC
CoCreate Modeling PE 3.0 has been released.
http://communities.ptc.com/community/more_communities/cocreate/cocreate_modeling_pe_-_english?view=overview#
Running on Windows 7, Vista and XP
Cheers
Horst
Oct 29, 2010 7:04 PM UTC
Hello
I am new to Co Create in fact just one day.
Win7 64 bit system I use, 8 gb ram i920 cpu
CoCreate installs and runs ok.
I have a problem with selections in general.
Today began to create a simple gear. Created invalute curve.
When I tried to mirror the curve plus one line it would only work if I launch Mirror.
Then loadthye selector and create a list.
Two points...the mirror is drawn but gives error on accepting the correct result.
Tried to add the file here also. Can send by email should anyone wish it.
Best
FJW
