Command Line Program in a mapkey
Does anyone know how, in a command prompt, to remove the last character in each line of a .txt file?
I need to open a family table instance, do one operation, close that instance then open the next instance and do the same thing.  And so on.
I am combining a mapkey with a batch file and I am close.  But I have to remove the last character in each line and I can't figure out how.
JLGAnswer
2-Explorer
October 14, 2015
I saved each page out as an .mht file; hopefully you can read them.
Steve,
you can do following (for example):
1.] install sed (stream editor) ... available at sed for Windows
2.] use command prompt command ... sed "s/.$//" a.txt > b.txt
a.txt ... source file
b.txt ... removed last character in each line
MH
Chris3
You don't have to install external sfotware. You might be able to do this with a batch, but vbs has a little more utility. In your config.pro, just change the .bat to .vbs and use the code below (with modifications as required)
Set objFS = CreateObject("Scripting.FileSystemObject")
strFile = "c:\test\file.txt"
strTemp = "c:\test\temp.txt"
Set objFile = objFS.OpenTextFile(strFile)
Set objOutFile = objFS.CreateTextFile(strTemp,True)
Do Until objFile.AtEndOfStream
    strLine = objFile.ReadLine
    ' Remove last character from strLine
     'This removes the carriage return and the last character and then adds the carriage return back
     strFile = Left(strFile, Len(strLine) - 2) & vbCrLf
    objOutFile.Write(strLine)
Loop
objOutFile.Close
objFile.Close
objFS.DeleteFile(strFile)
objFS.MoveFile strTemp,strFile
STEVEG21-Topaz IAuthor
Martin,
should have mentioned I can't install external software not approved by out IT dept.  But thank you for it.
Chris,
Thank you for the suggestion.  I might try that but I'd prefer straight command line commands.
2-Explorer
October 14, 2015
Unfortunately I do not have access to some sites from work.  Stack Overflow is one of them.
JLG2-ExplorerAnswer
2-Explorer
October 14, 2015
I DID IT!
I tried many different variations of what was on those pages.  But I never tried the example where they used the CALL command.  This is what worked.  Or at least seems to have worked.  I'l know once I get the mapkey and batch file all set.
Thank you so much.
SETLOCAL
for /f "delims=" %%a in (abc.pro) do (
set str=%%a
CALL :remove "%str%"
goto EOF
:remove
set str=%str:~0,-3%
echo %str% >> def.pro
:EOF
And just a little more information.
I also got a space at the end with this code.  It's easy to remove that actually.  I did some searching and found the answer.
Remove the spaces between the ">>" in the line echo %str% >> def.pro.  That space adds the space at the end of the line in def.pro.
So now it's:
echo %str%>>def.pro
