May 15, 2013 2:58 PM UTC
Common Folders v. Personal Favorites
In the latest update of creo at work, the window containing the model tree switches to Personal Favorites when all models are closed. It used to go to Common Folders. I have no use for Personal Favorites, and I prefer it to revert to Common Folders as it did before. I don't know what was changed in the latest update.
Does anyone know how to make the program do this?
    May 15, 2013 3:05 PM UTC
    Mine, Creo 2.0 M040 still goes to Common Folders when all models are closed. Are you referring to M050?
    redav1-VisitorAuthor
    May 15, 2013 6:17 PM UTC
    From the Help > About window:
    creo elements / pro 5.0
    Release: 5.0
    Date Code: M170
    I believe we were already using the M170 build, but changes were made to it, so I assume it is a matter of settings/options, not the software itself.
