May 21, 2015 5:58 AM UTC
Compatibility of Pro E 5 with Windows 8.1
Is pro e 5 compatible with windows 8.1? Clicking on setup file does not show up anything!!
Manish Papreja
Mahesh_Sharma
22-Sapphire I
May 21, 2015 6:44 PM UTC
Manish,
Wildfire 5.0 is not supported on Windows 8.1, Creo 2.0 M100 and later are supported on Windows 8.1. For Wildfire 5.0 try executing setup.exe using > Right Click > Run an admin, not sure it will start installation or not, however you can make a trial.
May 22, 2015 6:33 AM UTC
Manish,
you can copy Wildfire 5.0 installation from another PC to Windows 8.1 PC and test if it runs.
Martin Hanak
mpapreja1-VisitorAuthor
May 22, 2015 11:21 AM UTC
Dear Martin,
Thanks for the suggestion. Should be a good solution if it works but I don't know how to copy installation from one pc to another. I have another PC having Windows 7 32 bit where wildifire 5. is working fine and my target PC is having windows 8.1 64 bit. Could u please guide me in trying the suggested option?
Manish
