Component based repeat region is not populating through model view.
I am using Creo Parametric Release 6.0 and Datecode6.0.3.0
Connector pinout table is not populating.
Here are the errors that I faced
'A3' does not exist in the database.
Font arial.ttf.ndx can not be loaded.
WARNING: Cabling assembly ASM0001 is not in drawing; report tables may be wrong.
 Shaded model will be displayed
Axes will not be displayed.
Datum points will not be displayed.
Coordinate Systems will not be displayed.
Datum planes will not be displayed.
Axes will be displayed.
Datum points will be displayed.
Coordinate Systems will be displayed.
Datum planes will be displayed.
All tables have been updated.
Select a region.
Select a component in a view to drive the repeat region.
Model-dependent region items will be lost. Please confirm.
All objects in session are currently being displayed. No objects will be erased.
Select a region.
