component operations merge grayed out
Trying to merge two parts and finding that component operations, merge pick is grayed out.
Creo 2.0-m140, license PROE_Flex3c
Do I have a config option that's interfering?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
davehaigh13-AquamarineAuthor
Found the problem thanks to a suggestion by Ron Grabau.
default_ext_ref_scope was set to None, setting it to All fixed the issue.
I need to make a mapkey to toggle this setting.
David Haigh
There can be quite a few config options that affect this, I went through this with PTC support ~10 years ago. I made a config file called merge.pro that has every reference scope config option (they may have added some new ones since then):
allow_ref_scope_change YES
default_ext_ref_scope ALL
default_object_scope_setting ALL
default_object_invalid_refs COPY
ignore_all_ref_scope_settings YES
model_allow_ref_scope_change YES
scope_invalid_refs COPY
In Reply to David Haigh:
David Haigh
Is it possible to write a macro/utility/mapkey etc in WF3 to extract a part name parameter and then use that text line to name individual files in an export file set (step, igs, pdf) automatically?
Thanks in advance Jeff Dayman
