Dec 11, 2011 5:31 AM UTC
Config Error Madness
I suddenly started getting a config error whenever I start a new part, or even bring into session an existing part. This only occurs in WF4. Strangely enough, I have WF5 running from the same config.pro, and it doesn't have the same problem. I have no other config files (as far as I know, and yes, I've checked).
Here is the error message:
Line 20: Unknown keyword MECH_STR.
Line 21: Unknown keyword MECH_THR.
Line 22: Unknown keyword MOLD_OWNER.
Has anyone seen this before, and more importantly, know how to fix it?
Cheers!
20-Turquoise
Dec 12, 2011 4:51 PM UTC
Help | System Information
and then look for the section titled "Configuration files read:"
Pro/Engineer will tell you the configuration files read on startup. Look for the config.pro(s)
Fix as appropriate with your favorite text editor.
> Cheers!
> -----End Original Message-----
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
Dec 12, 2011 5:25 PM UTC
While I haven't seen it before...
The .pdf WF4.0 Config Options does not contain the three options giving you an error. With the frequency that config.pro options changewith each release, it couldeither be an obsolete option (pre WF4), or a WF5 only option (as you're using the same config.pro for bothWF versions.There is alsoa chance it's one of the many hidden options, but I don't have that list readily accessable so I can't be certain.
The solution is to remove them from your config.pro file.
In Reply to Lar Kerila:
Cheers!
SamuelBrantner
Mar 30, 2016 4:45 PM UTC
Hi Lar Kerila‌
check your Tree configuration file. WF4 does not have the settings: MECH_STR, MECH_THR and MOLD_OWNER.
So just save a new Tree file for WF4 and use it then it should work!
Greetings Sam
Greetings Sam
