Jan 23, 2013 12:21 PM UTC
config.pro, Cleaning duplicate entries?
I'm new to the software and made the mistake of saving "All" everytime I made a new mapkey. I now have a config file that is 177,026 lines long.
I've tried opening it up in a text editor and working on it but the way it's written out the file is very difficult to manage.
Is there a trick, tip, or tool to help clean this mess I've gotten myself in?
Thanks in advance.
(I did a search but some of them were a little out of date or didn't address the possibilty of a tool or method to help.)
James62Answer
Jan 23, 2013 4:21 PM UTC
Maybe try to load it in Pro/E or Creo and then export it from there into a new file.
James621-VisitorAnswer
Jan 23, 2013 5:05 PM UTC
You sparked a lightbulb for me. I see I can saved the currently loaded options to a seperate file. That'll make my job a little easier.
3-Newcomer
Feb 25, 2015 3:01 PM UTC
Hi
If you go to Olaf Cortens web site (ProESite - Olaf Corten's Pro/ENGINEER Site - Pro/E Utilities, Benchmark, Tips and Links) he has an on line tool that will detect any duplicates or any flaws in your config.pro and covers versions from PROE R20 up to CREO 3
slapha
Feb 25, 2015 8:36 PM UTC
We also have some comment markers in our Config files to show which are the config.pro and config.sup that are pushed to the text folder. Won't help for all the duplicates but it should help eliminate some of the extras.
