Nov 6, 2012 11:46 AM UTC
Config.pro & .dtl..help needed
Hey i need help ..
I am not able to find file name config.pro & .dtl file...i am useing Pro-e 4
I wan to do some chnges accrding to my need like
1. change drawing view display default setting
2. also want to map those file as default( so whne i start pro-e my settings will automatially set)
so plese help me for same
Nov 7, 2012 4:47 PM UTC
U have to create a config.pro file by saving the config file, place it to proengineer program folder text directory. Also you can make a combined bat file setting $pro directory and combined all default option. The later option may be used for advanced settings.
Regarding drawing view changing, please be spacific what are the changes your are exactly looking for?
Jayanta Sarkar
