Feb 11, 2016 5:44 PM UTC
config.pro duplicates including mapkeys
My recollection is the first item in the config will load and duplicated items will be ignored?  I can only assume this will occur for mapkeys of the same name?  I could test the theory but thought it would be nice to see it here.  I came here looking for an answer and did not find it.  I went to Google and did not find the answer.  The first place I looked was documentation and could not locate it there.
KenFarley
Feb 11, 2016 6:03 PM UTC
As I recall, the exact opposite is true. I had a parameter set in the beginning of my config.pro and didn't know it was also set further down. The last one was the winner, which drove me batty for a while, thinking my changes were being ignored, etc. You can test it yourself by setting a benign parameter, like
display wireframe
display shaded
Start up Creo and see whether you are in wireframe or shaded view.
Feb 11, 2016 6:21 PM UTC
If there is a config.sup in the load directory, this is run first and  this will assign the options and "lock" them.
Then, if there is a config.pro in the load directory, it will then assign these options, barring any changes from the locked .sup
Then if there is a config.pro in the start in directory, i will assign or overwrite the load directory config.pro options but barring any changes from the config.sup
Chris3
Feb 11, 2016 7:44 PM UTC
Any line further down in the config.pro takes precedence over any lines earlier.
For example if you have:
Line 1: display_points no
Line 12: display_points yes
display_points yes (Line 12) is the line that is loaded in. Any previous lines above it are over written.
Same applies for mapkeys.
2-Explorer
Feb 25, 2016 7:26 PM UTC
Hello Don,
Kenneth, Ron and Christopher are correct. See more details in this article in our knowledge database:
CS28227 : How does Creo Parametric retrieve config.pro options at startup
Gunter
